vertical scale
Postby rupertpage » Thu Oct 12, 2023 12:00 pm
I always use the autoscale all graph type option
However I had a historical value entered in one of my portfolios.
so the high value should be £2,100,000
but it is now defaulting to £3,500,000
I have deleted this high historical value...
any idea why this is happening ?
rupertpage
Postby Mark » Thu Oct 12, 2023 12:53 pm
Hi rupertpage,
If you use "View / Scale..." and apply the autoscale, does that correct it? Maybe it got set to a fixed value? If not, make sure you don't have any data or markers that would cause the scale to be set that high.
