Graphs not remembering date range
Postby rdr713 » Thu Apr 04, 2024 12:05 pm
How do I make a graph always show my desired date range?
For instance, if I select a date range of "1 year" (and, yes, then I save the portfolio), then when I start the program the following day I expect the graph to show one year to the current date. But instead it shows one year and one day: the ending date has changed appropriately but the starting date has not.
Thanks in advance for helpful hints!
rdr713
Postby Mark » Thu Apr 04, 2024 2:31 pm
Hi rdr713,
You can turn on the graph window option:
Graphs / Options / Display... / Start Date Floats with End Date
and that should get you what you're looking for.
