Seasonality graph feedback
Postby Djobydjoba » Sat Sep 28, 2024 6:13 am
I'm really impressed by the program, but if there's one thing I find really pointless it's the "Segment base 100" display type of the Seasonality graph. I've said it before, this way of displaying values (segments floating in the graph area) is very bad IMO. I've never seen something like this anywhere. And why would you display values like this instead of "Bar Base 100", which is a hundred times easier to read? IMO this display option could (should) be removed.
Postby Mark » Sat Sep 28, 2024 1:51 pm
It is an option, but you can of course use either of the other 2 display options. Right mouse click on the graph and choose "Seasonality Options..." and then under "Display" you have the 3 choices:
Bar (Base 0)
Bar (Base 100)
Segment (Base 100)
If you don't care for the last one, you can of course use either of the other 2...
Postby Djobydjoba » Sat Sep 28, 2024 2:20 pm
Yes, sure. I'm so into the software that options I don't use but which seem to me to be flawed bother me :)
