Right Hand Edge of Graph
Postby rm_organ » Sat Sep 19, 2009 7:59 pm
The natural right hand edge of a graph is the last date. But, I've experienced that the right hand is hard to see given that it sits against a black border. Is there a default way to make this easier to see- maybe putting a slight extra edege on the border of the graph that would make the last value easier to see? I have adjusted the right edge by putting a future date in - but that seems a bit "kluge". Any ideas?
Bob
rm_organ
Postby Mark » Sun Sep 20, 2009 12:57 pm
Hi Bob,
You can change the color of the border, to make it lighter if that helps? What graph type are you looking at? See "Options / Colors...".
