Professional
Postby wizard348 » Sat Oct 24, 2009 9:46 pm
I finally decided to spring for the Professional Fund Manager.
When I click on technical analysis, nothing comes up.
Please help.
wizard348
Postby Mark » Sun Oct 25, 2009 11:26 am
Do you see the Graph window? Is it just empty, or do you not see the Graph window at all? If you don't see the Graph window, try using one of the Tile or Cascade commands under the Window menu.
Postby wizard348 » Fri Oct 30, 2009 8:36 pm
I get the Graph window with the MA in it. But I tried hitting F10, I opened the Technical Analysis under Options under the Graph pull down. I get Technical Analysis Graph Options and I picked the default but nothing moves. It stays on my Expotential MA that I set up without Technical Analysis.
Can I get Version 9 Personal back again please ???
wizard348
Postby Mark » Fri Oct 30, 2009 9:21 pm
Hi wizard348,
What graph type do you have selected under the "Graphs" menu? You must have the "Technical Analysis" graph selected. If you're displaying one of the moving average graph types, the technical analysis options do not affect those graph types, only the "Technical Analysis" graph.
If you want to download 9.x it is still available here:
http://www.fundmanagersoftware.com/modlist.html#Last9x
Postby wizard348 » Sun Nov 01, 2009 9:00 pm
I love this software. I got version 6 or 7 way back when. I thought I would try the Professional but it just doesn't put anything on my screen.
I was in Technical Graphs and hit F10 and nothing..
I still have my version 9 file from where I downloaded it and it works fine. I wanted MACD and ROI .....
Oh well...
wizard348
Postby Mark » Mon Nov 02, 2009 8:38 am
Hi wizard348,
I'm sure we can get it working. Why don't you give me a call at (480) 705-0129, and we'll walk through it together. If you have a high speed internet connection we can do a quick web conference.
