Transaction retrieval problem at Schwab
Postby theobaldr » Thu Oct 29, 2020 7:01 am
I hope this resolves sooner than later. With current market, this is becoming painful.
theobaldr
Postby LungDoc » Fri Oct 30, 2020 11:22 am
I called Schwab today to add my complaint to this issue. The person I spoke with was aware of the problem, but had no useful solution. She agreed that the 2-6 week timeline was absurd. She was able to identify FM application and that it was in progress. Schwab customers should continue to register their complaints with Schwab.
LungDoc
Postby dbender54 » Fri Oct 30, 2020 12:13 pm
What group did you contact at Schwab to complain?
dbender54
Postby Good_Vibe » Fri Oct 30, 2020 12:31 pm
Mark:
Just heard from Schwab. They have assigned a "Client Advocacy" agent who claims he is able to gather the necessary technical resources at Schwab to help resolve the transaction receive problem. His name is Kenneth Russell; phone number 1-(800) 468-3744 extension 55543. He works 8 am to 3:00 pm CST. Hope he has the muscle to get things moving at Schwab. By the way, I just tested transaction module 241; failed.
Thanks, Phil
Good_Vibe
Postby Stefan » Sun Nov 01, 2020 7:01 pm
Just updated to FM 2020 so I can get the 241 transaction module. It doesn't work!
I checked my Schwab account and it has third party access via OFX enabled.
Please advise what I should do to get back the transaction retrieval functionality.
Stefan
Postby Stefan » Sun Nov 01, 2020 7:12 pm
Just found this link with what may be going on at Schwab and alternative solutions:
https://www.stockmarketeye.com/blog/sch ... rt-issues/
Stefan
Postby Stefan » Sun Nov 01, 2020 7:31 pm
What is the correct procedure to enter a buy/sell or dividend transaction manually? Until this Schwab issue is resolved I have to keep track of my transaction and update my portfolio in FM.
Stefan
Postby Mark » Sun Nov 01, 2020 9:13 pm
Hi Stefan,
We're still waiting on Schwab to re-enable access. We have met with them, and formulated a plan that required changes on both sides. We have implemented these changes, but are currently still awaiting Schwab to complete the necessary steps on their end. Unfortunately, I don't have an ETA on when these will be finished.
To manually record a transaction you can use the Data Register.
Postby Stefan » Sun Nov 01, 2020 9:44 pm
Thank you for the update. I think the most efficient workaround until this problem gets resolved is to export the transactions file from Schwab, delete the unnecessary heading and then import the transactions using the generic transaction import. For anyone interested in doing this, the import string format which matches Schwab transaction file is:
MM/DD/YY,TRAN,SYMB,NAME,BNUM,ANUM,CNUM. This format string works for Buy/Sell.
For dividends, you can use the same format string but replace the "Cash Dividend" in the Schwab file with DIST_D.
Stefan
Postby dbender54 » Sun Nov 01, 2020 10:24 pm
I appreciate the link to importing the transactions, but this is absolutely what I don’t want to have to do and the entire reason for using Fundmanager. Way too many accounts and potential transactions with mutual funds, stocks, etc. If I have to do this, I’ll just not use FM. Hopefully Schwab & FM will get this resolved.
dbender54
Postby theobaldr » Mon Nov 02, 2020 8:30 am
I just logged a complaint with my account exec at Schwab, and provided the name and number of the individual on the Schwab side that has been assigned. He has agreed to escalate the issue inside Schwab. I suggest others do the same and ask that it be raised to the powers to be.
Ray
theobaldr
Postby Clark » Mon Nov 02, 2020 9:01 am
I also contacted my account exec at Schwab
Clark
Clark
Postby Stefan » Mon Nov 02, 2020 9:24 am
Could someone please post the name of the person / group at Schwab in charge with this development? I want to contact my financial advisor as well and ask him to contact them and escalate.
Stefan
Postby theobaldr » Mon Nov 02, 2020 9:44 am
Taken from an earlier Post.
Ray
theobaldr
Postby dlevy » Wed Nov 04, 2020 8:23 am
I'm wondering if there is any status update. The market is volatile and year-end is not all that far away. At some point, I'm going to have to look at other solutions:
    (1) download csv transaction and position files from Schwab and write the software to get them into FM
    (2) explore Quicken as an intermediary
    (3) There are more extreme options which really do not appeal.
It would be really helpful to know how long we're likely to be without the Schwab interface.
With thanks,
David
dlevy
PreviousNext
