Vanguard Transactione Retrieve Error
Postby Mark » Wed Jan 08, 2025 5:31 pm
Thanks for the idea quercus. Something we may investigate...
Postby Bsrr » Thu Jan 09, 2025 8:29 pm
For what it is worth I received the same "standard" answer from Vanguard yesterday too.
I heard back from my colleague who was looking into our ability to make our website compatible. They informed me that the adjustments to our website to modernize it caused a lot of software like the one you use to lose compatibility. Since the updates that caused it are related to fortifying our security we are unable to make it work with the software you were using. Since this has had a negative impact on you I have submitted feedback to our continuous improvement team on how we can make things easier for you. You are not the first person to have feedback like this and the more they hear the feedback to higher chance for change to come. Please let me know if I can look into anything else for you.
Bsrr
Postby Bsrr » Thu Jan 09, 2025 8:35 pm
Mark - FYI - not having the ability to auto download from Vanguard would be very undesirable. I hope there can be a solution forthcoming. Thanks.
Bsrr
Postby Mark » Thu Jan 09, 2025 8:52 pm
Hi Bsrr,
Thanks for sharing that. Unfortunately, it appears Vanguard is blocking smaller apps like Fund Manager. If Vanguard intentionally blocks us, there isn't much we can do. The next best solution is to download and import. They do make it convenient to use the Download Center through their website and download a single .QFX file for all your accounts. You can import transactions for all accounts from this, and also use it to reconcile against. See this for some more specifics:
viewtopic.php?p=27079#p27079
It is less convenient than the automatic retrieve, but is a reasonable alternative.
Postby Cole » Fri Jan 10, 2025 8:17 am
Good morning Mark,
What the steps we can do to use the downloaded transactions to reconcile accounts?
Regards,
Cole
Cole
Postby m4boys27 » Fri Jan 10, 2025 9:00 am
I am also affected by the lack of Vanguard transaction download. I appreciate the workaround that was provided to download and import the .ofx file, and I am using that for now. However, I am hopeful that you will consider the suggestion to use Plaid or some other service that Vanguard supports to resolve the issue.
m4boys27
Postby Mark » Fri Jan 10, 2025 11:42 am
Hi Cole,
You can read about the steps needed to download/import/reconcile here:
https://www.fundmanagersoftware.com/faq_vanguard.php
Hi m4boys27,
Thanks for the feedback. We are planning to investigate Plaid as an option.
Postby Houstonwb » Sat Jan 11, 2025 7:39 pm
My .qfx files are associated with Quicken. The .ofx files are not associated. Will changing the .qfx file associations to Fund Manager disrupt Quicken in any way? Quicken is vital for my cash accounts.
Houstonwb
Postby Mark » Sun Jan 12, 2025 8:06 am
Hi Houstonwb,
Associating an app with a file extension just makes that the app that opens if you open or double click on a file with that extension. You can still use that file type in another program by initiating the action from within the program. For example, even if you don't have .QFX associated with Fund Manager you can still import a .QFX file into Fund Manager by using "File / Import / Transaction / Open Financial Exchange (*.OFX, *.QFX)..." and browsing to the file you want to import. It just makes it a bit easier if it is associated. If it is associated you can just double click on the .QFX file to open this file in that dialog box.
If you're concerned, just leave the associations the way they are now, and use the menu commands in Fund Manager to initiate the import.
Postby fmuser » Tue Jan 14, 2025 11:07 am
Better news from Vanguard!
After further investigation from the Product Team, they found that over the holiday, there was a change to security because of fraudulent activity which caused our systems to block 3rd party software and applications that previously worked. The business has decided to make additional changes and the Vanguard systems will be updated to allow clients to download their transaction history through applications like Fund Manager and Money Dance.
It may take a few business days for our systems to update, but it sounds like you should now be able to continue using Beiley Software/Fund Manager moving forward.
fmuser
Postby m4boys27 » Tue Jan 14, 2025 11:46 am
That's great news - thanks for sharing this info fmuser!
m4boys27
Postby RonB » Tue Jan 14, 2025 11:58 am
My Vanguard retrieve is working today!
RonB
Postby dellwo » Tue Jan 14, 2025 12:07 pm
Yay!! Mine works too!
dellwo
Postby Mark » Tue Jan 14, 2025 12:52 pm
Hi fmuser,
Thanks for sharing that. This is wonderful news! I too can confirm that Vanguard is once again working with Fund Manager in our testing.
Postby PWatson » Wed Jan 15, 2025 12:52 pm
This is wonderful news. I have been scrambling to find something that does what Fund Manager does, and while there are lots of financial and portfolio tools out there, I have yet to find one that does what FM does in the way that it does. So, I am indeed happy that I can stay with FM. Thank you, Mark.
PWatson
PreviousNext
