Yahoo server not working?
Postby Klaus » Mon May 08, 2023 6:13 am
HMI wrote:Thanks Mark and OT_Family.
I just tried Yahoo (Alternate) for one sub-portfolio and 12 out of 13 positions were updated without me adjusting any names/values, BUT it was very slow (over a minute as opposed to a few seconds when Yahoo is working). Yahoo (Germany) didn't work of any of my positions as currently set up.
Yahoo (Historical) seems to be working as usual, FWIW.
Hello
can confirm Yahoo - alternate is also working for me
KR
Klaus
Klaus
Postby Klaus » Tue May 09, 2023 10:19 pm
Hello
KR
Klaus
But VERY slowly
Klaus
Postby BARONEANDREA » Wed May 10, 2023 3:44 am
Yahoo Italy is still not working.
Any news?
Andrea
BARONEANDREA
Postby Mark » Wed May 10, 2023 9:18 am
Hi Andrea,
We're aware of the problem, and hope to have a solution soon. I'll post here when it is available, and you can always check the status under "Help / FM on the Web / Check for Updates...".
The current status is all of the daily Yahoo servers aren't working for customers in Europe. The Yahoo (Alternate) and (Historical) servers are still working, and can be used until we have a fix for the regular Yahoo servers.
Postby Mark » Thu May 11, 2023 1:52 pm
The quote module has been updated. Version 580 is available by selecting "Help / Fund Manager on the Web / Check for Updates..." from within Fund Manager 2022 or 2020. This update fixes the Yahoo quote servers.
Postby Klaus » Thu May 11, 2023 10:57 pm
Mark wrote:The quote module has been updated. Version 580 is available by selecting "Help / Fund Manager on the Web / Check for Updates..." from within Fund Manager 2022 or 2020. This update fixes the Yahoo quote servers.
Works, as fast as expected. Thx :D
Klaus
Postby scottlang21 » Tue May 23, 2023 5:29 pm
retrieving prices from Yahoo seems not work now, anyone else encountered same problem?
scottlang21
Postby Mark » Tue May 23, 2023 5:40 pm
Hi scottlang21,
Yahoo appears to be working properly when I'm testing it now with quote module 580. If you're still having troubles, can you let me know what quote module you're using (see "Help / About...") and an example ticker symbol that won't update, or just attach your price retrieve log (Help / Logs / Price Retrieve...).
Postby scottlang21 » Tue May 23, 2023 5:51 pm
Hi, Mark
presently, I use module 580, but I couldn't retrieve anything from yahoo from today. as I'm in China, I have to use vpn to retrieve data through Singapore. Could you please check, thank you!
scottlang21
Postby Mark » Tue May 23, 2023 6:17 pm
Hi scottlang21,
Interesting, I see the same issue when connecting from China. However, the prior quote module (579) still works from China (but not Europe). If you'd like to switch back to the 579 version, so you don't have to use a VPN, you can do so by downloading it with a web browser from here:
https://www.fundmanagersoftware.com/pro ... 4x_579.dll
After you download it, go into the "Properties...", and "Unblock" it. Place it in the same folder as your Fund Manager (FM.exe) and rename it to just inteng14x.dll. You'll have to rename or delete the current file in that folder first. Once you have this file in place, verify under "Help / About..." that you have quote module 579, and then you should be good to retrieve prices, as long as you're not in Europe.
Postby scottlang21 » Tue May 23, 2023 6:30 pm
Hi, Mark
Fine now, problem fixed, thank you very much for your help! attached retrieve log for your reference. hopefully some help.
really lucky to have Fund Manager since 2009
intlog_debug.txt
(91.89 KiB) Downloaded 213 times
scottlang21
Postby HMI » Tue May 23, 2023 10:49 pm
Thanks for sorting this with 580, which was working perfectly up until and including yesterday afternoon. Unfortunately it's no longer working for me this morning (in Germany).
HMI
Postby Arrow » Tue May 23, 2023 11:22 pm
Yahoo Italy is not working again.
FM PRO 2022.17.6.100
QUOTE MODULE 580
Any news?
Arrow
Arrow
Postby MattGMT » Wed May 24, 2023 1:15 am
In addition, Yahoo isn't working in the UK.
QM 580
Regards,
Matt
MattGMT
Postby Bohemianjl » Wed May 24, 2023 4:13 am
Yahoo is not working in Hong Kong too.
FM Personal 2022.17.6.100
QM 580
Regards
Jerry
Bohemianjl
PreviousNext
