by alan green » Sat Nov 14, 2020 6:48 am
Hi Mark, I am having the same problem with Fidelity. I get a winnet error code 12029 when trying to retrieve transactions. I have no problem retrieving prices.
Alan
alan green
by theobaldr » Sat Nov 14, 2020 9:03 am
Updated and reconciled all accounts last night. Really makes you appreciate how easy FM makes managing several accounts and keeps them up to date after working manually for the past 4 weeks.. Thank you.
theobaldr
by Mark » Sat Nov 14, 2020 9:35 am
alan green wrote:Hi Mark, I am having the same problem with Fidelity. I get a winnet error code 12029 when trying to retrieve transactions. I have no problem retrieving prices.
Alan
The 12029 error is usually from some local firewall program blocking access. Fidelity is working okay from here.
by Tnblade » Sun Nov 15, 2020 8:02 am
I am also having the same problem with Fidelity. Any suggestions?
Tnblade
by Mark » Sun Nov 15, 2020 9:56 am
If you're getting the same 12029 error message, check your firewall/anti-virus programs/settings. Some program is likely blocking access. I've just checked both Fidelity Investments and Fidelity NetBenefits, and they are both working okay from here.
by alan green » Sun Nov 15, 2020 10:49 am
I disconnected my windows defender which didn’t correct the problem
alan green
by bwessely » Sun Nov 15, 2020 12:31 pm
Mark wrote:Thank you to everyone for your patience. This OFX interface will be available until the end of the year, according to Schwab. We expect to have the new FDX interface completed/available before this time.
Still the same error "failed to retrieve portfolio". How did others get it to work again? I rebooted just in case and tossed the retrieval settings and re-entered them.
bwessely
by Mark » Sun Nov 15, 2020 12:49 pm
alan green wrote:I disconnected my windows defender which didn’t correct the problem
Something is blocking it. It might be some other sort of antivirus program or something?
by Mark » Sun Nov 15, 2020 12:50 pm
Did you download the latest transaction module 241? Use "Help / FM on the Web / Check for Updates..." from within FM 2018 or 2020.
by Tnblade » Sun Nov 15, 2020 2:56 pm
I disabled my antivirus program and am getting the same error message trying to get Fidelity to update. Code 12029.
Tnblade
by Mark » Sun Nov 15, 2020 5:35 pm
Tnblade wrote:I disabled my antivirus program and am getting the same error message trying to get Fidelity to update. Code 12029.
1) What transaction module are you using? See "Help / About...". 2) Where are you connecting from? Is it within the US?
by Tnblade » Sun Nov 15, 2020 6:40 pm
Thanks Mark,
Transaction Module 241.
Connecting from home computer in US.
It was working fine a month or so ago.
Tnblade
by Mark » Sun Nov 15, 2020 8:20 pm
Hi Tnblade,
I'm not sure then. The 12029 error indicates a connection couldn't be made from your computer to Fidelity's OFX server. I'm not able to reproduce the problem here. Do you retrieve from any other brokers? Do you have problems with those?
by tommydom » Mon Nov 16, 2020 6:40 am
Mark, Everything works well for me now. Thank you very much for getting this all fixed up. Tommy. Mark wrote:Thank you to everyone for your patience. This OFX interface will be available until the end of the year, according to Schwab. We expect to have the new FDX interface completed/available before this time.
tommydom
by Tnblade » Mon Nov 16, 2020 5:32 pm
Mark wrote:Hi Tnblade,
Mark, Yes, it works fine with Vanguard and Schwab. Fidelity had been working until recently. Thanks Rodney
Tnblade
