updating dividends
Hi rromagna,
You can do this in the Data Register. Select "Edit / All Data..." to open the Data Register. Set the "Data Type" to "Distributions (all)". You can now select the sub-portfolio and investment you want to work with, and press the "New..." button to add a new distribution manually.
Hi rromagna,
If you are manually entering dividends, you would need to do it for each separate holding of the investments. If you have many of these, it is usually easier to import if you can get it in some sort of electronic format from your broker.
Hi rromagna,
Thanks for the feedback. That would make sense, we'll see about doing this.
Return to Prices and Transactions Who is onlineUsers browsing this forum: No registered users and 5 guests |
