Cannot download prices from MSN
Postby RoyS » Tue Jan 25, 2011 10:28 am
I have been running with FM for a couple of months now and have successfully downloaded my (UK) prices from MSN - but am now unable to do so.
Last successful download was 31/12/2010. I tried today on this PC for the first time since then and got 'Cannot update any investments' error message. As far as I know, nothing has changed - MSN set as default quote server, FM 10.8, Quote Module 420, Transaction Module 138. I have tried copy and paste of fund symbols from MSN website and also made FM an 'exception' to Windows firewall - to no effect.
In the last few days, I installed a second copy of FM on to a PC in a different location using a restored backup of data and settings to get started. Everything worked fine except, again, could not download prices from MSN.
All advice very welcome - thanks - Roy
<<Edit. When I submitted this post, I got an FM Error Message 'Oops - page error 500' or similar, altho' the post was received and posted. Coincidence or relevant??>>
RoyS
Postby Mark » Thu Jan 27, 2011 8:22 am
Hi Roy,
Can you give me an example symbol you are trying to retrieve? If you go to MSN's website, can you look up this symbol okay?
Postby Mark » Thu Jan 27, 2011 8:39 am
Hi Roy,
You may also find this topic helpful:
http://www.fundmanagersoftware.com/foru ... .php?t=932
It describes what symbol you need to use to retrieve UK unit trusts from the MSN quote server.
Postby RoyS » Thu Jan 27, 2011 8:49 am
Mark - thanks for getting on to this.
An example is GB:GB00B09DMJ2 for Artemis Strategic Bond.
I should stress that I was successfully downloading MSN prices up to 31/12/2010 using symbols of this format but then found I had lost this capability when I tried again a few days ago.
best wishes - Roy
RoyS
Postby Mark » Thu Jan 27, 2011 1:38 pm
Hi Roy,
Thanks. I was able to reproduce the same problem. Version 421 of the quote module is now available that fixes this server. See "Help / FM on the Web / Check for Updates..." to get the latest price module.
Postby RoyS » Fri Jan 28, 2011 6:19 am
Mark - download now works fine with new module.
Many thanks - Roy
RoyS
