Retrieving from Vanguard.
Postby aviator » Sun May 22, 2011 4:25 am
I'm having trouble retrieving transactions from Vanguard. When I make an attempt, I get the following error message:
Post HttpSendRequest
WinInlet error code: 12038
Message: The host name in the certificate is invalid or does not match.
Just before I attempted the download, I installed transaction retrieve module 145. I'm not sure if this is related to my problem or if this is a Vanguard issue.
Postby DGreenfield » Sun May 22, 2011 10:42 am
I am getting the same error code when I try to receive transactions from Vanguard.
DGreenfield
Postby aviator » Sun May 22, 2011 11:30 am
Mark and DGreenfield,
This appears to be a Vanguard issue. A Quicken forum had similar posts.
Fairly sure this has nothing to do with the latest transaction retrieve module.
Postby Mark » Mon May 23, 2011 9:03 am
Hi aviator and DGreenfield,
Thanks for the problem report and info. I've just checked it now, and it appears to be working correctly. It sounds like Vanguard had a temporary issue, and has fixed it. If you are still having troubles, please let me know.
Postby aviator » Mon May 23, 2011 1:02 pm
All is well with Vanguard. I called their tech support this morning and they said they'd email me when the issue was resolved. I received their email about an hour ago and tested a transaction download in Fund Manager and Quicken. Both worked.
Postby Mark » Mon May 23, 2011 1:11 pm
Excellent, thanks for the confirmation.
