EXUD1 Transactions and IB Import
Postby BradN » Wed Feb 29, 2012 7:35 am
A common transaction that FM is not recognizing in the .trn import is EXUD1.
Some examples are below...
Interactive Brokers||U954***|EXUD1||OCR 6 7/8 12/15/15|FI|08/05/2011|696.00||0.00|||||||OCR 6 7/8 12/15/15(US681904AK42) TENDERED TO US681CALLK46 1 FOR 1 (OCR 6 7/8 12/15/15, OCR 6 7/8 12/15/15, 681904AK4)
Interactive Brokers||U954***|EXUD1||US681CALLK46|FI|08/05/2011|696.00||0.00|||||||OCR 6 7/8 12/15/15(US681904AK42) TENDERED TO US681CALLK46 1 FOR 1 (US681CALLK46, OCR 6 7/8 12/15/15 - PARTIAL CALL, 681CALLK4)
Interactive Brokers||U862***|EXUD1||HK|EQ|08/24/2011|300.00||0.00||||||||HK(US7164951060) TENDERED TO HK.WDR 1 FOR 1 (HK, PETROHAWK ENERGY CORP, 716495106)
Interactive Brokers||U862***|EXUD1||HK.WDR|EQ|08/24/2011|300.00||0.00||||||||HK(US7164951060) TENDERED TO HK.WDR 1 FOR 1 (HK.WDR, PETROHAWK ENERGY CORP - WAIVE DISS RIGHTS, 716WDR994)
Interactive Brokers||U912***|EXUD1||EMN|EQ|10/03/2011|50.00||0.00||||||||EMN(US2774321002) SPLIT 2 FOR 1 (EMN, EASTMAN CHEMICAL CO, 277432100)
Regards,
Brad
BradN
Postby Mark » Wed Feb 29, 2012 9:07 am
Hi Brad,
Thanks for the samples. Our documentation doesn't have an EXUD1 transaction code. Can you explain what is happening for these transactions? If you look at your first example, it just gives a share quantity of 696.00, but no amounts are listed.
Postby BradN » Mon Mar 05, 2012 1:45 pm
That is a case of a partial lot redeem for the OCR bond (fun stuff). The rest seem to be much tamer, consisting of old fashioned stock splits.
Another code that came up was PIL (Pmts in Lieu). By replacing "PIL" with "DIV" in the .trn, file I seemed to have fixed the issue (still need to really check it, though). I will take the same approach to EXUD1 and replace it with "Split." I am guessing that is the term FM will recognize. I will keep you posted.
Brad
BradN
Users browsing this forum: minvestor and 2 guests
