loading brokerage transactions history
Postby mangier62 » Fri Sep 14, 2012 3:28 pm
I have connected to my broker and downloaded transactions for the last 24 months into 7 subportfolios for each separate account at this brokerage. I had previously downloaded earlier transactions that began 3 years ago into excel and would like to include these earlier transactions with the recent downloaded transactions. I only know how to enter these older transactions manually which is very time consuming because I have about 400 transactions that would need to be entered manually.
Is there a way to import these transactions from a csv files into my existing subportfolios? If so could you please direct me on how to accomplish this.
mangier62
Postby Mark » Fri Sep 14, 2012 4:15 pm
Hi mangier62,
Yes, you can do this. You would need to use the "Generic" transaction import, which is at "File / Import / Transactions / Generic...". I would suggest going to this dialog and pressing the "Help" button which will explain how to use this import routine. You'll need to format your Excel data into a compatible format, and enter a format string during the import. Save from Excel to a .CSV format, and then import this CSV file. You can't directly import a .XLS file, as that is a binary file.
The generic import is powerful, but is also not trivial to get working without reading the online help, and looking at some of the examples.
