prices.csv
Postby Philip323 » Sun Dec 02, 2012 6:01 pm
can not located prices.csv in windows 8 used to be in C:\Users\xxx \AppData\Roaming\Fund Manager in W7.
Philip323
Postby Mark » Mon Dec 03, 2012 10:59 am
Hi Philip323,
Are you able to locate your user's AppData folder okay? Are you not able to find the folder, or can you find the folder but just not that one file?
Postby Philip323 » Mon Dec 03, 2012 11:30 am
I was able to find it in the Fund Manager\Log Folder apparently it was a hidden file as I could't search for it until I activated show hidden files.
Thank you
Philip323
