Employee Option Awards
Postby stuartma66 » Sun Jun 30, 2013 2:21 pm
Anybody have a good trick for manually entering employee options? My thought was to put in the underlying stock and a negative cash account for the strike. Was hoping somebody had a cleaner method. All I'm interested in tracking is the intrinsic value of each award.
stuartma66
Postby Mark » Sun Jun 30, 2013 2:24 pm
Hi stuartma66,
That method will work, as long as the options are not "under water". I don't have a better suggestion than the one you've described.
Postby stuartma66 » Sun Jun 30, 2013 2:30 pm
Thanks for the reply, as I'm entering now the method I suggested works fine for me.
stuartma66
