dai;y change
Postby alpappy » Tue Oct 29, 2013 5:32 pm
HI is is possible to show the daily change in portfolio view and if possible the % daily change rather than the change since last update?
thanks
alan
alpappy
Postby Mark » Tue Oct 29, 2013 5:35 pm
Hi alan,
Are you talking about in the Portfolio Editor window? If so, yes. Just select "View / List Columns..." and put a check mark next to the fields:
Value Change
% Change
Both of these are the change from the current computer date, to the prior day.
Postby alpappy » Tue Oct 29, 2013 5:41 pm
HI I tried that but shows 0 in both Is that because I am in Nz and the computer date throws it out?
alan
alpappy
Postby Mark » Tue Oct 29, 2013 6:10 pm
Hi alan,
Maybe... Look at the value as of your computer's date, and look at the value on the day before. Are they the same? If so, that would cause it to show 0 for the change numbers.
Users browsing this forum: No registered users and 28 guests
