"Access Denied" Problem
Postby jgdickens » Mon Dec 09, 2013 12:19 pm
Somehow my Investment (.dat) files are getting saved to a Read-Only folder and I'm having trouble permanently changing the folder properties to remove the restriction. Is there some way to direct the .dat files to another folder that I create? I'm not seeing that in the File or Edit options. Is there some way to move the existing .dat files to a friendlier folder? Portfolio (.mm4) file is OK.
jgdickens
Postby Mark » Mon Dec 09, 2013 1:13 pm
Hi jgdickens,
Yes, you can use "File / File Operations / Set Data Location..." to move everything to a folder of your choice.
Postby jgdickens » Mon Dec 09, 2013 1:30 pm
Thanks Mark; I knew there had to be a simple solution.
jgdickens
Postby jgdickens » Mon Dec 09, 2013 1:33 pm
Mark- I have an older version (9.6) that doesn't have a file option for "Set data location" under File Operations. Assume that comes in a newer version?
jgdickens
Postby Mark » Mon Dec 09, 2013 1:35 pm
Hi jgdickens,
Yes, that feature was added as of 12.0.
Postby jgdickens » Mon Dec 09, 2013 1:37 pm
Super! Looks like an update required...Thanks again
jgdickens
Users browsing this forum: Google [Bot] and 6 guests
