Stockwatch Server Again
Postby Bruce Woytuik » Fri Mar 07, 2014 4:27 pm
Stockwatch seems to be down again
Bruce
Bruce Woytuik
Postby Mark » Fri Mar 07, 2014 6:31 pm
Hi Bruce,
Thanks for the notice, I see the same problem. We'll have to investigate.
Postby Sheldon » Fri Mar 07, 2014 11:17 pm
Further to Bruce's post, the historical retrieve for the Stockwatch server is not working correctly either. It may be due to the same problem as the daily retrieve.
Sheldon
Sheldon
Postby Mark » Sat Mar 08, 2014 3:32 pm
Hi Sheldon and Bruce,
Quote module 457 is now available (Help / FM on the Web / Check for Updates...) that fixes both of these servers.
Postby Sheldon » Sat Mar 08, 2014 4:12 pm
Thanx, Mark.
Sheldon
Sheldon
Postby Bruce Woytuik » Sun Mar 09, 2014 12:25 pm
Thanks Mark
Bruce Woytuik
Postby aldenxi » Fri Mar 14, 2014 5:16 pm
I'm on Personal Version 10.5 - How do I install the new module without having to install a newer version of fund manager :?: John A.
aldenxi
Postby Mark » Fri Mar 14, 2014 7:22 pm
Hi aldenxi,
The new quote module is not available for the 10.x versions. We only provide quote module updates for the last 2 major versions, which are currently the 11.x and 12.x versions. You would need to upgrade to get the updated quote module.
Postby gwdavies » Sat Mar 15, 2014 6:09 am
I have had similar difficulties obtaining Canada Stockwatch prices since March 1. I typically update only weekly, on a Saturday. Historically, whenever I need to update one of the INTENG files the automated download is often unsuccessful and I manually download. The version of INTENG10X.DLL I manually downloaded on March 8 did not fix the problem, but the version I downloaded on March 9 did. However, the next time I tried to retrieve Stockwatch prices (today, March 16), I was unsuccessful. I currently have Quote Module 454 and Version 11.1.
Other than this periodic glitch updating prices, the software is very stable and the product is outstanding. I have been using it regularly for 15 years.
Gareth
gwdavies
Postby Mark » Sat Mar 15, 2014 9:43 am
Hi Gareth,
The Stockwatch server changed twice in a couple week period. You'll want to get the latest quote module, 457 if you want to retrieve from this server. There was a bug in early 11.x versions that prevented the download from working right. I would suggest downloading the last 11.x version, which is 11.9 from our site here:
http://www.fundmanagersoftware.com/modlist.html#Last11x
After you download/install 11.9, go into Fund Manager and select "Help / FM on the Web / Check for Updates..." and allow it to download the update. It should work with 11.9, where it wouldn't with 11.1. If all goes well you should end up with quote module 457. BTW, this is inteng11x.dll for your version.
Postby gwdavies » Sat Mar 15, 2014 10:06 am
That did the trick. Thanks very much.
Gareth
gwdavies
