Import generic transactions issue
Postby milli1905 » Fri May 09, 2014 2:41 am
I have an import of generic transactions issue. I have changed the naming of portfolios in FM and I have added account number. When importing using the generic option FM does not recognize the Portfolio Name and/or Account number and executes the import into a new sub portfolio.
I have only added the account number to the portfolio and not to any instruments or the cash account.
How to solve?
Milli
milli1905
Postby Mark » Fri May 09, 2014 8:50 am
Hi Milli,
Make sure you are using the ACCT key in your format string, and it is placed where you have the account number on each line of your importing file. The ACCT field matches your sub-portfolio account number.
If you still have problems, please post the format string you're using, and a sample line from your importing file.
Postby milli1905 » Fri May 09, 2014 1:22 pm
I still have the problem:
Here are the strings
MM/DD/YY,PORT,CURRENCY,TRAN,SYMB,BNUM,ANUM,CNUM,NAME,ITYPE,ASSET,GOAL,ACCT!REM YYYY
4/25/2014,AA10247_P1220,SEK,Sell,HM-B.ST,280,275.60,59,H & M B,Stock,Consumer Discretionary,Sweden,1687124600
milli1905
Postby Mark » Fri May 09, 2014 2:19 pm
Hi Milli,
That looks correct.
When you import it, what sub-portfolio does it get imported into?
I test imported this using your format string and data line, and it correctly went into a sub-portfolio with the name "AA10247_P1220" and account number of "1687124600". Are you sure your sub-portfolio account number is set properly, with no extra space characters?
Postby milli1905 » Fri May 09, 2014 2:26 pm
There was a hidden tab after the account number. I've added a trim to the generator and now it works.
Thanks for pointing me in the right direction.
milli1905
