soome copied positions not updating
Postby alpappy » Fri May 09, 2014 3:52 pm
Hi I copied some positions into a new portfolio Copied using the file menu but left the data data blank I then bougt a new position in the new (copied) shares Some worked fine but a number do not updata just show the buy price I have retrieve on and have tried a few servers All look like they have the data but does not update on the holding?
Any ideas
thanks
alan
alpappy
Postby Mark » Fri May 09, 2014 4:16 pm
Hi alan,
Are you asking why some of your investments are failing to retrieve pricing? If so, check "Investment Properties... / Internet Retrieve" and make sure "Retrieve Price" is checked. Also, see the quote servers and make sure the recorded symbols are available on those servers. For a complete list of items to check, see:
http://www.fundmanagersoftware.com/faq_ ... ailure.php
Postby alpappy » Fri May 09, 2014 5:26 pm
yes all checked still shows buy price no update Yet same investment in another sub portfolio does update I think the new from existing is causing the problem
alan
alpappy
Postby Mark » Fri May 09, 2014 5:55 pm
Hi alan,
How are you verifying the closing price data? Use the Data Register with the "Prices" data type. that shows your recorded closing prices. If you still have troubles, please tell me the symbol, quote server, and quote module version you're using.
