Bond Amortization and the Generic Transaction Interface
Postby dlevy » Fri May 16, 2014 5:36 pm
I'm trying to import bond amortizations through the Generic Transaction Interface.
To verify the how to code it, I did a bond amortization through the FM UI and did a generic file export. The amortization created two transactions:
[symbol] [date] DIST-4 -100.00 0 0 # records as amortization
[symbol] [date] DIST-R 100.00 0 0 # records as return of capital
So, I followed these as models in formatting data exported from another portfolio management package. The DIST-R transaction imported correctly. The DIST-4 did not import at all.
My format string is SYMB,ED,TRAN,ANUM,BNUM,CNUM
Sample data:
544644QL4,20090701,DIST_4,-46.63,0,0
544644QL4,20090701,DIST_R,46.63,0,0
I note that the documentation for the generic file import (http://www.fundmanagersoftware.com/help ... neric.html)
does not document the DIST-4 transaction, but mentions only user-defined DIST-1 and DIST-2.
Should I be able to import a DIST-4 transaction?
Am I doing something else wrong?
With thanks,
David
dlevy
Postby Mark » Fri May 16, 2014 6:12 pm
Hi David,
That looks like a bug in the generic export. We used to have 4 user-defined distribution types, but the last 2 were changed to be used for accretion and amortization. Change DIST_4 to DIST_T, and then that should import properly. (DIST_3 should be DIST_A for accretion)
Postby dlevy » Fri May 16, 2014 6:22 pm
Yes!
That works perfectly.
Thanks, Mark!
David
dlevy
