Dividend Import Issue
Postby milli1905 » Fri May 23, 2014 5:59 am
I have an import issue with dividends.
I have following import string:
05/23/2014,AA10246_P1218,UTDI.DE,UNITED INTERNET N,458,1687124598,DIST_D
and following format:
MM/DD/YY,PORT,SYMB,NAME,ANUM,ACCT,TRAN!REM Dividends
When running the import I get "The specified import format is illegal!"
I've looked through the investment and I can't find a irregularities. The fil is created as a .CSV file.
What am I doing wrong?
Milli
milli1905
Postby Mark » Fri May 23, 2014 9:28 am
Hi Milli,
You are missing BNUM and CNUM from your format string. These are required fields. Even though a DIST_D type transaction doesn't need them, they are still required. You can just add them, and use 0 for their values.
