Fidelity Bonds
Hi Baabr,
How did you "add munis" to your account? Did you buy them, transfer them in, or how? However you got those munis, should have a corresponding transaction. If you retrieve transactions for the date where the munis were added to your account, you should get transactions to represent this. If not, try temporarily turning off the "Skip transactions already in Fund Manager" option, to see if they aren't already in there somehow, and you're just not seeing them. Go "Back" or "Cancel" at the Preview screen, so you don't actually import twice. If you can't find any record of these transactions when retrieving, then you can check the transaction retrieve log file, and see if they are mentioned at all. You can find the xmldump.txt log file here: C:\Users\<username>\AppData\Roaming\Fund Manager
Sorry for the delay in responding, but I was on the road for a few weeks. I bought the bonds. I tried all of your recommendations (checked transactions in the appropriate account during the period surrounding the purchase date, checked xmldump.txt log file, and turned off "skip ..."), and the bonds did not appear. But, they do show up in Reconcile. Any other suggestions? Also, today my Vanguard accounts wouldn't update (has nothing to do with the bond problem).
Hi Baabr,
If you retrieved transactions over a date range where you purchased bonds, and you see no sign of those transactions in the xmldump.txt file, then for some reason your broker isn't providing them. You would need to contact your broker and ask them why they're not showing up in the transaction feed. The Vanguard OFX server recently underwent some changes, so we had to release an update. Use "Help / FM on the Web / Check for Updates..." to download the current transaction module (196). That should resolve the Vanguard issue.
Return to Prices and Transactions Who is onlineUsers browsing this forum: No registered users and 16 guests |
