by nebfinfm » Mon Sep 22, 2014 6:55 am
Hi Mark, again I have a trouble with retrieving bond prices from Boerse Stuttgart (BS). The same problem I reported previously - see below the ===line. Today I attempted to retrieve "Gol Finance DL-Notes 2010(15/20) | ISIN USG3980PAD71. First time I used BS own symbol "77732518", second time I used ISIN "USG3980PAD71" - no luck. See the messages
(1) Retrieve Starting Quote Module Version = 517 Retrieving from server: (BOERSE STUTTGART) Requesting: "77732518" Could not update any investments WARNING: Server used but did not update any prices: (BOERSE STUTTGART)
(2) Retrieve Starting Quote Module Version = 517 Retrieving from server: (BOERSE STUTTGART) Requesting: "USG3980PAD71" Could not update any investments WARNING: Server used but did not update any prices: (BOERSE STUTTGART)
Thanks nebfinfm == old report ================================== For some time I have been trying to retrieve several bond prices from Boerse Stuttgart. I'm following exactly your instructions - but no success. Now, I did change retrieving to other servers, but some titles are available only on BS. For example below is a message for USD bond Grupo Papalero isin USP49768AA59. -------------------- Retrieving from server: (BOERSE STUTTGART) Requesting: "77605867" WARNING: Server used but did not update any prices: (BOERSE STUTTGART)
nebfinfm
by Mark » Mon Sep 22, 2014 9:13 am
Hi nebfinfm, Thanks, I saw the same problem. We needed an update for this server, which has just been released. Please let me know if you still have troubles once using the updated quote module (471): viewtopic.php?f=2&t=3203
by nebfinfm » Tue Sep 23, 2014 4:17 am
It appears that retrieving from Boerse Stuttgart now work okay. Another question: can FM download prices from Luxembourg Exchange? I remember while ago that we talked about it.....
Thanks nebfinfm
nebfinfm
by Mark » Tue Sep 23, 2014 7:44 am
Hi nebfinfm, can FM download prices from Luxembourg Exchange?
I'm not sure... You might look on our existing quote servers to see if they offer quotes from this exchange. For links to all the quote servers, see: https://www.fundmanagersoftware.com/intrtv.html
by nebfinfm » Tue Aug 15, 2017 12:07 pm
nebfinfm
by Mark » Tue Aug 15, 2017 12:38 pm
Hi nebfinfm, The instructions for what to use for the symbol for this server are a bit unique. See the instructions here: https://www.fundmanagersoftware.com/int ... #StuttgartFor the investment you're looking for, the symbol would be: GOL-Finance-bond-USG3980PAD71-Times-und-Sales-264 I just test retrieved this, and it worked properly.
by nebfinfm » Tue Aug 15, 2017 12:49 pm
Hurray, it work. Many thanks. nebfinfm
nebfinfm
by nebfinfm » Tue Nov 07, 2017 4:38 am
Mark, unable to retrieve from Borse Stuttgart "Casino,Guichard-Perrachon S.A. | ISIN FR0010154385" As per your instructions I entered into symbol field "Casino-Guichard-Perrachon-SA-bond-FR0010154385*264" (* replaced "-Times-und-Sales-"). Retrieve was unsuccessful viz:
Retrieve Started at 11/7/2017 11:24 UTC Program Version = 2018.15.0 Quote Module Version = 522 Retrieving from server: (BOERSE STUTTGART) Requesting: "Casino-Guichard-Perrachon-SA-bond-FR0010154385*26" WARNING - Unable to update: "Casino-Guichard-Perrachon-SA-bond-FR0010154385*26" WARNING: Server used but did not update any prices: (BOERSE STUTTGART) Could not update any investments
Thanks for help. Nebfinfm
nebfinfm
by Mark » Tue Nov 07, 2017 8:03 am
Hi Nebfinfm,
Unfortunately, the symbol is 1 character too long for Fund Manager. Notice, you meant to record it as:
but it is only:
Fund Manager's symbol can be 49 characters long, and this is 50.
by Mark » Tue Nov 07, 2017 11:38 am
Hi Nebfinfm, No, those servers aren't on the list. You can try others to see if you can find it. Links are here: https://www.fundmanagersoftware.com/intrtv.html
by Mark » Tue Nov 07, 2017 11:53 am
Thank you Djobydjoba. Nebfinfm, This means you can retrieve it from the FondsCheck server using the symbol 675305. For more, see the instructions for the FondsCheck server.
by Mark » Wed Nov 08, 2017 10:33 am
Hi Nebfinfm,
We use the term "importing" to mean bringing data in from a file on your PC. If you want to "retrieve", you can only retrieve prices from quote servers we have added support for into FM. The sites you mentioned are not currently supported for retrieving. If those sites have an option to download prices in a CSV file, then you could import prices from that downloaded CSV file.
