Reinvestment Transactions - Schwab
Postby gcm223 » Thu Oct 02, 2014 11:34 am
I use the Advisor level software and the Schwab Institutional download of data.
None of my ETF reinvestments posted on 9/30/14. Is there something in the asset set up that I should be doing to get these to re-invest?
gcm223
Postby Mark » Thu Oct 02, 2014 8:15 pm
Hi gcm223,
Do you see the distributed distributions? You may see them as distributed distributions, plus separate purchases, depending on how they are reported by Schwab.
Postby gcm223 » Fri Oct 03, 2014 7:39 am
On the Schwab system the dividend posted on the 26th and the reinvestment occurred on the 29th.
gcm223
Postby Mark » Fri Oct 03, 2014 8:13 am
Hi gcm223,
If that is how Schwab reports it, that is how FM will import it. You could double check by looking in your *.TRN file with a text editor, and see how all the transactions are dated. If you want, you can send me a couple sample *.TRN files, along with a specific dividend in question, and I can take a look for you.
Users browsing this forum: Bing [Bot] and 13 guests
