Unable to open a bunch of dat files after update.
Postby richard » Mon Nov 10, 2014 10:06 am
Am using
FM 2014.13.4
QM 472
TM 198
I updated to the above this morning and several of my data files where no longer able to open. I could open them before the update. I think that the update was the TM file.
Said was created with a previous version of FM. When I said to convert, says data file is either incomplete or incorrect format.
Can I send you the file or have you any ideas.
Richard
richard
Postby Mark » Mon Nov 10, 2014 10:12 am
Hi Richard,
What if you restore either just these investments, or all your data from a *.FMB backup file?
