Unable to retrieve transactions
Postby jackpgunn » Tue Jan 13, 2015 8:44 pm
For years I have had no problems retrieving transactions from Charles Schwab and now, maybe because I upgraded to the latest version, I am getting a message saying Failed to Retrieve Portfolio. I read some of the other posts and I know you suggest that it may be a firewall issue but I am able to retrieve prices. When I try to check for updates I get the 12029 error message. Any thoughts?
Thank you
jackpgunn
Postby Mark » Tue Jan 13, 2015 9:00 pm
Hi jackpgunn,
What version of Internet Explorer do you have installed on your system?
Try opening up Internet Explorer, and go to "Tools / Internet Options... / Advanced" and click on both "Restore advanced settings" and "Reset... / Reset". Fully exit, and re-start both Internet Explorer and Fund Manager after doing this, and then try retrieving again.
Postby jackpgunn » Tue Jan 13, 2015 9:11 pm
No luck. Same error message.
jackpgunn
Postby jackpgunn » Tue Jan 13, 2015 9:12 pm
I have Explorer 9.0
jackpgunn
Postby Mark » Tue Jan 13, 2015 9:18 pm
1) Can you retrieve from other brokers? Is it only Charles Schwab?
2) If you go look in the (hidden) folder:
Windows XP and earlier:
C:\Documents and Settings\<username>\Application Data\Fund Manager
Windows Vista and later:
right after you do a retrieve. Do you have a "ofxretr.txt" file with a date/time stamp equal/later than the "ofxpost.txt" file? If you open that up in Notepad, are there any clues in there? You can email us that log file, and we can take a look.
Postby jackpgunn » Tue Jan 13, 2015 9:31 pm
I apologize. l can't even find the file in which you are referring.
jackpgunn
Postby Mark » Tue Jan 13, 2015 9:33 pm
Can you find that folder? It is a hidden folder, so you have to turn on the display of hidden files/folders. If you still can't find it, why don't you call the office tomorrow, and we can look at this problem together.
Postby jackpgunn » Tue Jan 13, 2015 9:37 pm
I am lucky that I can even turn on the computer. I will give you a call on Thursday, tomorrow is not good. Thanks for your help so late in the evening.
jackpgunn
