dividend reinvestment
Postby ben.com » Tue Feb 10, 2015 3:32 pm
Hello Mark,
I want to register a reinvested dividend and I wonder how I should register the balance of the dividend. As I'm french, I prefer to take an example :oops:
For example :
share : 100
dividend : 0.5 per share
==> gross dividend = 50
reinvestement price : 15
reinvestment number : 4
==> balance of dividend = 50 - 15*4 = - 10
How should I regsiter this -10 ?
ben.com
Postby Mark » Tue Feb 10, 2015 3:39 pm
Hello,
If the dividend amount is different than the amount you spent to buy additional shares, you may want to record it as a separate dividend plus a purchase. Alternatively, you can record the dividend as reinvested for part of the shares you bought, and a separate buy for just the difference between what the dividend paid for and what you spent out of pocket.
Option 1: Record a distributed dividend for 50. Record a purchase of 4 shares for 60.
Option 2: Record a reinvested dividend for 50/15 (3.333) shares for a total of 50. Record a purchase of 10/15 (.667) shares for a total of 10.
Both are equivalent in terms of performance.
Postby ben.com » Tue Feb 10, 2015 3:49 pm
Thanks for your answer.
The important point is that both solution are equivalent in term of performance.
So, I think I made a mistake. I register :
- a reinvestied dividend for 4 shares @ 15
- a distributed dividend for -10
I think this is not a good for the performance, isn' it ?
ben.com
Postby Mark » Tue Feb 10, 2015 3:55 pm
That isn't quite the same... I would record it with one of the 2 methods I mentioned, as it more accurately reflects what happened.
Postby ben.com » Tue Feb 10, 2015 4:09 pm
Yes you're right.
But I want to follow my portfolio performance dividend included and dividend excluded.
So I think that option 1 and 2 have not the same impact in term of those two performances.
With the option 1, I register a distributed dividend of 50. I bought for 60
With the option 2, I register a reinvested dividend of 50. I bought for 10
Are distributed dividend and reinvested dividend treated the same way in the performance ?
ben.com
Postby Mark » Tue Feb 10, 2015 4:23 pm
A reinvested dividend is exactly the same as a distributed dividend plus a purchase when it comes to performance. In both cases you have 50 of dividends and 60 of purchases.
