Trouble with split-adjusted historical prices
Postby fmnewbie » Thu Mar 12, 2015 12:17 pm
One of the stock positions I track (VOD) is refusing to adjust historical prices after I entered a split. So the share-price graph shows a huge price drop on the date of the split, with all prices afterwards displaying correctly but all prior ones incorrect.
The stock was purchased in 1995. Originally it was purchased in 3 separate accounts (all 3 lots purchased on same date), but in 2010 the assets of all 3 accounts were combined into one. So in 2010 there is a "transfer out" listed in each of the first two Fund Manager investment files, and a corresponding transfer into the third file.
VOD has split 3 times: in 1999, 2006 and 2014.
I've taken the following troubleshooting steps:
- added all 3 splits in all 3 FM investment files (the files in each of the first two accounts are still open, with zero value)
- deleted and re-retrieved all historical prices in all 3 investment files
Still no luck. I've double-checked the historical prices on Yahoo for dates before and after the latest split, and I think they are only incorrect by the ratio of the latest split, although it's hard to tell.
Can you help?
--Andrew
fmnewbie
Postby Mark » Thu Mar 12, 2015 12:25 pm
Hi Andrew,
What quote server are you using exactly for historical prices? If you're recording the split transactions, then you want to retrieve actual closing prices, which you can get with "Yahoo (Historical)". If you get actual closing prices, and record splits, then when you turn on "View / Split Adjusted", you should not see the drops.
Verify your data is recorded correctly by turning off "View / Split Adjusted", and look at your recorded closing prices in the Data Register. You should see all the closing prices recorded as they were on those dates. So, for example, if the price dropped from $100 to $50 after a 2:1 split, you should see this in the Data Register when "View / Split Adjusted" is off. When you turn on "View / Split Adjusted", the pricing will show smoothly around $50, since you have the 2:1 split transaction recorded here.
