Prices will not update
Postby raysk » Fri Apr 24, 2015 3:18 am
I get a popup that says system error 2
"the system cannot find the file specified"
This has happened the last two days.
HELP
Ray
raysk
Postby raysk » Fri Apr 24, 2015 3:36 am
Figured it out.
I have not used explorer in years since I started using chrome.
Yet when I opened and checked explorer it was in the working offline setting. Really can't figure out just how that happened. Soon as I set explorer back to online I could update.
raysk
Postby Mark » Fri Apr 24, 2015 7:30 am
Hi raysk,
Glad you figured it out. Yes, Fund Manager uses a component of Internet Explorer to handle the connections to the quote servers.
