Price retrieval samples
Postby marathon » Thu May 07, 2015 12:00 pm
Is there a consolidated place to find current and historical price retrieval samples, especially for funds and bonds across the different servers?
spent most of time just searching across the documentations (some parts are cryptic) and the forums
much easier if there was more "meat" with actual examples for this page:
https://www.fundmanagersoftware.com/intrtv.html
marathon
Postby Mark » Thu May 07, 2015 12:04 pm
Hi marathon,
What kind of samples are you looking for? Do you mean sample ticker symbols for different quote servers? The general idea is you just find the ticker symbol as used on whatever quote server you want to use. Record that symbol in your Fund Manager investment properties, and then you can retrieve.
Postby marathon » Thu May 07, 2015 12:14 pm
actual examples
e.g. for a fund named ABC you could use either
1. morning star the code they use is ABC1234 and the website shows this
or
2. bloomberg and the code is AAABC123:US
a good template to follow is the much improved MSFT documentation, especially for excel
there is always a window at the bottom that shows the figures, and the formula and the expected outcome
this is useful for self-help because can try out the given example first, and work backwards to the actual security trying to find the right settings
in summary:
many many more real examples which a user can try to enter into portfolio and get the outcome shown in the example
marathon
Postby Mark » Thu May 07, 2015 12:28 pm
Hi marathon,
Okay, thanks for the feedback. I can see that being helpful.
