by Mark » Tue Oct 27, 2015 8:00 am
Hi ssuravarapu,
You can check if the Vanguard OFX server has this account by using the New Portfolio Wizard with an empty account number. You should get a listing of all the account numbers available for the login credentials you enter. It may be that the account number is listed in a slightly different way than you're expecting. If not, maybe it is under a different login. You might call Vanguard, and ask how to retrieve transactions for Quicken, as both Quicken and Fund Manager use the same OFX interface. Whatever instructions you get for Quicken you can use with Fund Manager.
Sometimes it is up to the particular plan custodian on whether or not they want to make the accounts available via OFX.
If the account isn't available to retrieve transactions, you wouldn't be able to get prices retrieved from the broker either. If the investments aren't quoted anywhere on any of our supported quote servers, you'd have to manually update the prices.
