Blockede by Bloomberg
Postby Alexanderfrood » Fri Jul 08, 2016 5:48 am
I have been using Bloomberg for quite a while to download fund prices on about 50 of my personal holdings (I am not a professional adviser). I have been blocked by Bloomberg for breaching the terms of service and when I asked why, they emailed back...
Use or attempt to use any “scraper,” “robot,” “bot,” “spider,” “data mining,” “computer code,” or any other automate device, program, tool, algorithm, process or methodology to access, acquire, copy, or monitor any portion of the Service, any data or content found on or accessed through the Service, or any other Service information without the prior express written consent of BLP are not permitted under our terms of use policy (http://www.bloomberg.com/notices/tos/). Downloading data from the website is not permitted.
If you would like access and download our data, please contact our sales team.
http://www.bloomberg.com/professional/request-demo/
Their link sends me to a page that assumes that I am a professional adviser.
Does anyone else use Bloomberg, as I thought it was OK to download using Fund Manager for private purposes.
Alexanderfrood
Postby Mark » Fri Jul 08, 2016 9:20 am
Hi Alexanderfrood,
It sounds like Bloomberg has tightened up their TOS rules. Another user reported this same problem yesterday. Unfortunately I think this means we will need to remove Bloomberg from our list of quote servers, and try to find a replacement.
Postby Alexanderfrood » Fri Jul 08, 2016 9:31 am
Thanks for the reply.
In that case, how do I use the Morningstar UK server? I tried following the instructions from the server page but the price does not update. For example, Liontrust Special Situations I Inc has a code in the URL of F00000JWHC. However, when I put that code in the symbol box and select Morningstar UK Unit Trusts as the server, the price does not update.
Alexanderfrood
Postby Mark » Fri Jul 08, 2016 9:39 am
Hi Alexanderfrood,
Did you make sure to select the quote server "Morningstar UK - Unit Trusts"? I just tested this ID, and it retrieved the price properly. There are several quote servers that start with "Morningstar", so make sure to choose the one that says "Morningstar UK - Unit Trusts".
Postby Alexanderfrood » Fri Jul 08, 2016 9:43 am
Yes, it is the Morningstar UK - Unit Trusts. Still does not work. The symbol box has F00000JWHC entered.
The log says...
Retrieve Starting
Quote Module Version = 494
Retrieving from server: (MORNINGSTAR-UK)
Requesting: "F00000JWHC"
WARNING: Server used but did not update any prices: (MORNINGSTAR-UK)
Alexanderfrood
Postby Mark » Fri Jul 08, 2016 10:11 am
Do you have on the option:
Options / Internet Settings... / Proxy Server / Use Windows Settings
Can you view this price online by going here:
http://www.morningstar.co.uk/uk/funds/s ... F00000JWHC
If so, and you still cannot retrieve this price, try retrieving the price by itself by right mouse clicking on it, and choosing "Retrieve Selected Price". If it doesn't update, email me this file:
C:\Users\<username>\AppData\Roaming\Fund Manager\intlog2.txt
I will send you an email, so you can reply to that with the attachment.
Postby Alexanderfrood » Fri Jul 08, 2016 10:16 am
Yes, selecting Windows Settings seemed to do it. It downloads now.
Many thanks
Alexanderfrood
Postby Mark » Sat Jul 09, 2016 3:54 pm
We have published an updated quote module (495) that removes the Bloomberg quote servers due to this Terms Of Service limitation. This new quote module adds support for new Quandl quote servers.
