Captool Conversion & Splits
Postby ljbc01 » Fri Jan 27, 2017 12:23 pm
I am importing Captools data to Fund Manager using the Excel Template provided.
When the conversion runs against my Captools data SPLIT transactions are translated to:
DATE,SYMB,#N/A,#N/A,#N/A,CNUM,MEMO
i.e the TRAN,ANUM,BNUM fields are not translated. All others are correct.
The TRAN ids for splits in Captools are: SP+ SP-
How can I convert Splits?
Can you update the template to handle splits or do I have to do it manually (ugh!)?
Thanks - Lloyd
ljbc01
Postby Mark » Fri Jan 27, 2017 2:03 pm
Hi Lloyd,
If you want to email us a sample data file you're trying to convert with some split transactions, along with an explanation of the split transactions (are they a 2 for 1, etc), we can update the template.
Postby ljbc01 » Fri Jan 27, 2017 5:16 pm
I have attached a file with Captools Split transactions including an explanation of each transaction.
- Lloyd
Captools Sample Split Xactions.csv
Sample with explanation - hope this is useful
(2.12 KiB) Downloaded 316 times
ljbc01
Postby Mark » Mon Jan 30, 2017 11:31 am
Hi Lloyd,
Thanks for the sample. We've updated this conversion template, and posted the update here.
You should see the split transactions supported. If not, make sure you see the revision 2 item listed under the Revision History section on the "Mappings" sheet.
