Imported Transactions from E*Trade
Postby hipped1 » Fri Jan 27, 2017 2:59 pm
I recently made some bond investments in my Etrade account and imported the transactions. It does not appear that the purchased accrued interest was correctly imported, the total value is correct and the qty of bonds is correct, but the price per unit is not correct (its the total of the bond principal amount plus accured interest divided by qty bonds).
I don't see a way to edit the imported transactions since there is no field for accrued interest on the opening transaction, only value, shares, price and commission. If I create a new transaction, the accrued interest field is available.
Any suggestions on fixed the imported transactions without having to delete and manually re-enter?
hipped1
Postby Mark » Fri Jan 27, 2017 3:08 pm
Hi hipped1,
You can edit the buy transaction, and add a new distribution of type "Interest Income" with a negative value for the paid accrued interest. When editing the buy transaction, remove the amount paid for accrued interest, as you'll be replacing that with the negative distribution.
