GETTING CRUMB error 12156
Postby alciati » Thu Jun 08, 2017 1:53 am
HI Mark
I can dot download historical prices with yahoo.
Using FM 2016 Professional Module 517-223
If I retrieve one single/all security historical price I get GETTING CRUMB instead of the ticker and then WinINET error code: 12156 and no price is downloaded.
can you please help?
Andrea
alciati
Postby Mark » Thu Jun 08, 2017 6:48 am
Hi Andrea,
What exact version of Fund Manager are you using? See "Help / About...".
Postby alciati » Thu Jun 08, 2017 8:02 pm
Pro 2016.14.10.100
Quote 517
Module 223
today still same problem.
alciati
Postby Mark » Thu Jun 08, 2017 10:22 pm
Hi Andrea,
Please download the latest version, 2016.14.14. After installing this, do a "Help / FM on the Web / Check For Updates...". When done you should have 2016.14.14 with quote module 517. This should resolve this issue.
Postby alciati » Fri Jun 09, 2017 3:09 am
Great, it works now.
But now I can not download FX price using WSJ. both spot and historical? have they changed any settings/ticker? it used to work. thanks
alciati
Postby Mark » Fri Jun 09, 2017 5:52 am
Hi alciati,
I see the same problem with WSJ. The site isn't downloading quotes as it used to. It doesn't work with a web browser either, so we will need to wait and see if WSJ fixes this.
Postby B2B_Investing » Tue Jun 20, 2017 7:25 pm
I am getting the same error as well trying to pull historical information from Yahoo (Yahoo (Historical)). Could it have anything to do with the merger with Verizon?
Installed
Main Program: 2016.14.14.100
Quote Module: 517
Transaction Module: 224
Jason
B2B_Investing
Postby Mark » Wed Jun 21, 2017 9:58 am
Hi Jason,
Which error exactly? The "GETTING CRUMB" status is normal. If you're getting 12156, then check to make sure cookies are enabled in Internet Explorer on your system.
Postby B2B_Investing » Sun Jul 09, 2017 5:09 am
You are correct. I saw the getting CRUMB in the status but the error was 12156. That fixed it. I think something changed at Yahoo recently as I had not accepted cookies before and it has been working.
Thanks again for an excellent product!
Jason
B2B_Investing
Postby Mark » Sun Jul 09, 2017 9:23 am
Hi Jason,
You are right, the requirements for cookies with Yahoo is a fairly recent change.
