WSJ versus Yahoo
Postby Tim M » Thu Nov 02, 2017 4:53 pm
Mark, could you comment on the pros/cons of using the WSJ server versus Yahoo? In short, why has Yahoo been the default? Will it still be faster than WSJ after your expected changes? Thanks.
Tim M
Postby Mark » Thu Nov 02, 2017 5:22 pm
Hi Tim M,
Previously Yahoo was much faster, as it retrieved 10 quotes in a single request. It looks like we're going to have to change Yahoo, so it is only able to get 1 quote/request. The speed will likely be similar, or a bit slower than WSJ. The WSJ server also requires that you have the investment "type" set properly in order to get a quote.
Postby danmcco » Thu Nov 02, 2017 6:01 pm
Mark -- made google RT default server and changed all Canadian symbols to google version. Question is, what alternative server can be used for US option quotes?
danmcco
Postby Mark » Thu Nov 02, 2017 6:03 pm
Hi danmcco,
Yahoo (Options) is still working.
Postby danmcco » Thu Nov 02, 2017 6:45 pm
Mark -- thanks I'm aware of that. I'm just wanting to plan for the future, which could be anytime if Yahoo pulls the plug.
danmcco
Postby Mark » Thu Nov 02, 2017 6:57 pm
Hi danmcco,
Yahoo (Options) is the only quote server I'm aware of that offers option quotes.
Postby SeanD » Thu Nov 02, 2017 7:11 pm
Where / how do we find the right "type" for the WSJ quote server?
Sean
SeanD
Postby Mark » Thu Nov 02, 2017 8:02 pm
Hi Sean,
It is usually clear, just based on what the investment is, but you can also tell by looking at the URL on the WSJ site. For examples, see:
https://www.fundmanagersoftware.com/intrtv.html#WSJ
Postby rupertpage » Fri Nov 03, 2017 3:00 am
Hi Mark
Thanks for the new quote module. Yahoo price quotes are now much slower for my portfolios of UK stocks. But as I only usually did an end of day update I can live with it.
I thought I might try WSJ and Google price updates for separate sub portfolios (UK stocks):
1. Google: This seems to work fine without changing the symbol BUT you have to change the price factor as it prices in pence as opposed to Yahoo in £
2. WSJ: I could not get this to work for UK stocks. I tried changing the symbol to UK: xxx and UK. xxx with the type "stock"
rupertpage
Postby Mark » Fri Nov 03, 2017 5:04 am
Hi rupertpage,
Did you try looking up your UK quotes on the WSJ site?
