Vanguard and 403b accounts
Postby Cole » Tue Dec 05, 2017 6:16 pm
I have many clients that have 403b accounts through Vanguard. Vanguard has recently changed where another group (Newport Group) is the custodian of 403b accounts. I still access all accounts through Vanguard's website, but Fundmanager is unable to retrieve transactions, reconcile any of my clients 403b accounts from Vanguards site.
So I have several questions. Has anyone else run across this problem? If so, were you able to remedy this situation?
Also, I'm able to download all transactions to a CSV file. Can I use this upload transactions into Fundmanager fairly easily and efficiently? I want to avoid having to manually enter in all transactions (purchases, sales, distributions etc.)
Any help would be greatly appreciated.
Thanks, Cole
Cole
Postby Mark » Tue Dec 05, 2017 7:02 pm
Hi Cole,
I don't recall anyone else running into this yet. Yes, you can import from a CSV file, but other formats would be easier, like OFX, QFX, or QIF. With CSV you may have to massage the data, or create a helper spreadsheet, and then use the "Generic" import where you have to specify the format of your CSV file. It can be done, but is a bit more tricky than the other more specifically defined file formats. See the instructions for the generic transaction import.
Users browsing this forum: Majestic-12 [Bot] and 5 guests
