Have used yahoo now can't
I have used yahoo and yahoo historical seamlessly for my routine updates for a long time now, but not in the past several weeks; I haven't done any updates at all for nearly a month. Now it won't work at all. What have I missed? What can I try instead?
Hi tomseeley,
What quote module are you using? (See "Help / About...") What happens exactly when you try to update? Do you get an error message?
I'm also unable to use Yahoo (regular and Historical). It worked fine last Friday.
I'm using: Professional Version: 2018.15.3.100 Quote Module: 530 Transaction Module: 234 An error message about a missing file appeared, then an error similar to the following one in the log file: ERROR: Check that you are not "Working Offline". In Internet Explorer un-check "File / Work Offline". Could not update any investments Other quote servers seem to be OK
Hi LynneB,
Please try to clear up this issue by using Internet Explorer to go to: https://finance.yahoo.com It must be Internet Explorer, and not some other web browser like Chrome or Firefox. If you can successfully browse there using Internet Explorer, try again with Fund Manager after doing this.
Thank you very much for the help. The yahoo finance site has a revoked security certificate, hence Internet Explorer (and Fund Manager) wouldn't access it.
I had to disable the security option to check for revoked certificates (Go to Internet Explorer's Settings' Advanced options). I hope Yahoo fixes their web site soon!
Return to Prices and Transactions Who is onlineUsers browsing this forum: No registered users and 6 guests |
