Generic Prices Import problem
Postby aldenxi » Sat Jun 09, 2018 6:44 am
Hi Mark, I've been importing for years with no problem but suddenly (after a W10 update that rebuilt my entire system... poorly) the generic import prices is failing me. What's wrong with my import string?
aldenxi
Postby Mark » Sun Jun 10, 2018 3:49 pm
Hi aldenxi,
You can't tell for sure by looking at the CSV in Excel. It hides certain characters. Instead, open the CSV file in a text editor, like Notepad. A couple of guesses:
1) Does your symbol really have double quotes around it in the CSV file?
2) It looks like you have a space character after "YY," and "LL,". Do you also have a space in your CSV file at these spots? If not, you don't want a space in your input format string either.
Postby aldenxi » Sun Jun 10, 2018 4:54 pm
It looks like the problem was your first suggestion which was hidden characters in the .xml file + removing the quotes around the symbol. I saved it as text file (viewing it with notepad gives nonsense) and voila, all is well. I tried the the .xml file again without the quotes but it still failed. Thanks Mark.
John A.
aldenxi
