overwrite share prices
Postby kosmicmisfit » Fri Dec 28, 2018 8:01 am
hello
What is the best way to overwrite share prices as some of the charts in FM are not appearing correctly. Its UK stocks.
thanks
kosmicmisfit
Postby kosmicmisfit » Fri Dec 28, 2018 8:15 am
Also to overwrite unit trusts. As data historical data in not available and Portfolio graphs are skewed to the upside due to incorrect data.
http://www.morningstar.co.uk/uk/funds/s ... F000000AT8
kosmicmisfit
Postby Mark » Fri Dec 28, 2018 10:36 am
Hi kosmicmisfit,
Anytime you retrieve prices, existing prices for the same dates will be overwritten by the retrieved prices. You can retrieve, import, or manually enter prices. To manually adjust prices use the Data Register and select "Prices" under the "Data Type".
