Yahoo Historical Quote server asking for Username & PW
Postby sbfree » Thu Jan 17, 2019 3:35 pm
Hi:
The Yahoo Historical Quote server did not work and opened a window asking for Username & Password. This has never happened to me before. Has something changed with the quote server or do I need to set up a Username and Password there? Is this still the best historical quote server to use in the US?
scott
sbfree
Postby Mark » Thu Jan 17, 2019 3:49 pm
Hi Scott,
The image doesn't show here. I just tested Yahoo (Historical), and it is working okay here with no password prompt. You don't need to enter a password to retrieve, I'm not sure where that password prompt is coming from...
Postby sbfree » Fri Jan 18, 2019 5:10 pm
Thanks for the reply. I am still getting the request for a password. I think I've figured out how to attach screen shots.
Maybe that will clarify. When I check the server's status, it looks good.
Regards,
Scott
Request Quotes.png (18.09 KiB) Viewed 1813 times
Password requested.png (18.54 KiB) Viewed 1813 times
Quote in Progress.png (14.89 KiB) Viewed 1813 times
sbfree
Postby Mark » Fri Jan 18, 2019 6:46 pm
Hi Scott,
Can you check that you have cookies enabled in IE. See the instructions here:
https://www.fundmanagersoftware.com/faq_cookies.php
Also, can you browse to Yahoo's site with IE and look up your quotes and historical data okay?
