WSJ price retrieve issue since change in some URLs
Postby Djobydjoba » Sat May 25, 2019 12:24 pm
WJS has changed some URLs for indexes pages this week, and many can't be downloaded anymore with the new symbols (URLs).
Just an example:
DJUSVA
old URL part (=old symbol): index/XX/NULL/DJUSVA
new URL part (=new symbol): index/XX/DOW JONES GLOBAL/DYUSVALA -> this doesn't work
Many indexes are concerned : DJUSTC / DJTBAK / DJTFVS / DJUSRE, XIN9, etc...
Another example,
old URL part (=old symbol): index/UK/NULL/UKX
new URL part (=new symbol): index/UK/FTSE UK/UKX
Maybe an issue with the space character(s) introduced in the URLs?
Postby Mark » Sat May 25, 2019 2:41 pm
Yes, I see this same issue. It is a problem with the spaces. The spaces must be replaced with:
%20
So, in your example if you use the symbol:
index/XX/DOW%20JONES%20GLOBAL/DYUSVALA
that will work.
I'm not sure all browsers show it this way, but for me, in Chrome it does show the URL with the spaces replaced with %20, so you can just copy/paste the symbol from the URL displayed in the browser:
Spaces shown as %20 in URL
Postby Djobydjoba » Sat May 25, 2019 3:01 pm
I see now, thanks.
I use the chromium based browser "Vivaldi". With this browser, it seems %20 are not displayed in the address bar (maybe an option). If the entire URL is copied (with https://), the %20 are then copied and pasted, but if only a part of the URL is copied, spaces are pasted instead of %20, and that is what I had done.
Postby SteveK » Mon Jul 13, 2020 8:12 am
Hello sir,
I cannot retrieve prices for:
https://www.wsj.com/market-data/quotes/KE/XNAI/KCB
https://www.wsj.com/market-data/quotes/KE/XNAI/KNRE
but i can retrieve for:
https://www.wsj.com/market-data/quotes/KE/XNAI/COOP
Where is the difference ?
In all cases I am using just the symbol e.g in the last one COOP.
Let me know please.
regards,
Mark wrote:Hi Djobydjoba,
%20
that will work.
SteveK
Postby Mark » Mon Jul 13, 2020 8:36 am
Hi SteveK,
With this server you need to use everything after ".../quotes/" as the symbol. For example, your first one should have a symbol of:
KE/XNAI/KCB
I just test retrieved this symbol, and it is working okay from here. For more details on using this server, see our instructions.
