by drwehby » Sat May 25, 2019 1:27 pm
Hello, I've been successfully retrieving from Fidelity for many years. Now I get an error message: "Failed to retrieve portfolio" for all my Fidelity accounts. The error message is followed by my correct username and account numbers. I have no problem retrieving portfolio from TD Ameritrade. Fidelity website is up (I can access the accounts directly via web browser), but I can't retrieve portfolio info with Fund Manager. I'm running Fund Manager Pro 2018.15.15.100 with quote module 538 and transaction module 237 on a Win10 laptop. I would appreciate help in resolving this issue. Thank you.
drwehby
by divinest » Sat May 25, 2019 1:32 pm
I am seeing the same type of error with fidelity accounts - here is what the txn ret logs indicate. <HTML><HEAD> <TITLE>Internal Server Error</TITLE> </HEAD><BODY> <H1>Internal Server Error - Read</H1> The server encountered an internal error or misconfiguration and was unable to complete your request.<P>
divinest
by Mark » Sat May 25, 2019 2:28 pm
This appears to be an issue with Fidelity's OFX server. I am able to reproduce the same problem here with both Fund Manager and Quicken. Hopefully the issue will be resolved by Fidelity soon.
by divinest » Sun May 26, 2019 7:15 pm
Appears the issue is resolved now as of 10pm ET
divinest
by drwehby » Sun May 26, 2019 7:17 pm
Good to know-- thanks for checking.
drwehby
by aviator » Mon May 27, 2019 1:58 am
divinest wrote:Appears the issue is resolved now as of 10pm ET
Thanks for letting us know.
by bssylvester » Fri May 31, 2019 2:00 pm
This problem with Fidelity appears to be back. It's about 1:45PM PDT, and I'm receiving the same "Failed to retrieve portfolio" message when trying to download transactions.
I triple-checked the login name, password, and account number -- all correct. All my software is current versions. Per Mark's earlier suggestion, I called Fidelity and they walked me through how to access a Fidelity account using Quicken. No help. You essentially provide the same info as required by Fund Manager and the link is made automatically.
Any suggestions?
bssylvester
by drwehby » Fri May 31, 2019 2:07 pm
bssylvester wrote:This problem with Fidelity appears to be back. It's about 1:45PM PDT, and I'm receiving the same "Failed to retrieve portfolio" message when trying to download transactions.
Any suggestions?
Yes, I'm having the same error, again, too.
drwehby
by tslee0000 » Fri May 31, 2019 11:33 pm
I had the same problem. Do we know it’s fidelity problem or fm problem this time?
tslee0000
by chhabs » Sat Jun 01, 2019 7:34 am
I am also receiving the same error. Is there any way to check the status of the Fidelity ofx server?
chhabs
by Mark » Sat Jun 01, 2019 7:53 am
Hello all,
We are able to reproduce the same problem here with both Fund Manager and Quicken. The Fidelity Investment's OFX server is reporting an internal server error. It is a problem on Fidelity's end that they will need to fix. You can view the log file from within Fund Manager under "Help / Logs / Transaction Retrieve (Raw)...".
by tslee0000 » Sat Jun 01, 2019 3:48 pm
Thank you for the update. I talked to a Fidelity rep and he told me they are having issues with Quicken download and don’t expect the download to be up and running until a Monday. Thanks.t
tslee0000
by divinest » Sun Jun 02, 2019 3:47 pm
Appears the issue is resolved as of 6:45 pm ET - (06/02) - hope Fidelity finds the root cause and fixes the issue from happening again.
divinest
by onlyme » Fri Jun 14, 2019 3:20 pm
Seems that this same Fidelity issue has begun to occur once again as of this evening, Fri, 6/14/19 at 6:15 pm.
onlyme
by RonB » Fri Jun 14, 2019 8:47 pm
Just dropping a note that I'm having this Fidelity retrieval error also tonight at 8:45 PM Pacific so Fidelity still seems to be having intermittent problems
RonB
Users browsing this forum: Google [Bot] and 15 guests
