On PRC I get the following error
wininet error 12002
message the opening timed out
never seen this before any fix
Still using Beta
Alan
ERROR
Hi Alan,
Make sure Fund Manager has access to the internet, and isn't being blocked by some security program you're running. Can you use "Help / FM on the Web / Check for Updates..." okay?
Hi alan,
1) What quote server are you using? 2) If you try a different quote server, do you get the same error message? 3) Can you browse to the quote server you're using with Internet Explorer?
Return to Prices and Transactions Who is onlineUsers browsing this forum: Google [Bot] and 64 guests |
