Generic transaction import
Postby flight » Sat Nov 23, 2019 6:07 pm
I'm attempting to do a generic transaction import using this format, SYMB TRAN MM/DD/YY ANUM BNUM CNUM.
The problem I'm running into is some of my symbols have a space in between them such as "MSFT OPTION".
Can you advise or recommend what I should do?
thank
flight
Postby Mark » Sat Nov 23, 2019 8:02 pm
Hi flight,
You should use a character for separating the fields that you wouldn't be using in your data. For example, a comma or tab character. If you change your data fields to be separated by a comma, the format string would then look like:
SYMB,TRAN,MM/DD/YY,ANUM,BNUM,CNUM
and then you can have a space character in the SYMB field.
Users browsing this forum: No registered users and 88 guests
