UTX Spin off and Name Change
Postby divinest » Fri Apr 03, 2020 9:53 am
Hi Mark, what is the recommended way to track the spin off scenario with UTX to track it? with name change, distribution and the OTIS, RTX and CARR Thanks
divinest
Postby Mark » Fri Apr 03, 2020 9:57 am
Hi divinest,
I'm not familiar with the specifics of that company's spin-off, but you can probably use the spin-off wizard. If something changes names, you can simply change the name. If you have more questions, please tell me the specifics of what you're trying to record.
Postby divinest » Fri Apr 03, 2020 10:01 am
Sounds good, will let the transaction download update those and review them.
divinest
Postby divinest » Sat Apr 04, 2020 6:19 am
Hi Mark Here is the scenario
UTX stock spin off & name change
UTX name changed to RTX (RAYTHEON TECHNOLOGIES CORP) - UTX shows as all shared redeemed and added as RTX
CARR one share for each share of UTX owned
OTIS .5 shares for each share of UTX owned
The transactions downloaded and reconciles with the brokerage
Wanted to see how the cost basis; out of pocket costs should be handled in each of the above 3.
Thanks!
divinest
Postby Mark » Sat Apr 04, 2020 9:22 am
Hi divinest,
Besides shares, you'd also need to find out how much of your cost basis was moved to those new investments. Hopefully you can get this from your broker. If not, you may need to research it online, or contact RTX as usually this is specified in the details of the spin-off.
For the UTX -> RTX, just change the name/symbol/CUSIP properties, and maybe record a note on that date.
For CARR/OTIS use the spin-off wizard twice. To use this, right click on RTX and choose "Investment Data / Spin-Off..." and enter in the information there. As I mentioned you'll need to know how much cost basis needs to be transferred to the child investments.
Postby divinest » Sat Apr 04, 2020 9:58 am
thanks Mark - that works
divinest
