Fractionnal split question
Postby MichelV » Fri May 08, 2020 6:59 am
One of my position got a 1:20 split resulting in 163.25 shares. Since the fractional was less then .50 the issuer rounded it to 163 shares without changing the cost. I cannot figure out how to make the proper correction. I've tried many "Distribution" types, Tx Out, Sell. Nothing seems to give the proper result.
- If I leave the position has is, the market value will always be off by 0.25 x price, making month-end reconciliation more complicated
- If I "Adjust" -0.25 shares the Tax basis value decreases while this is not true. The "Price cannot be $0" seems to be part of the problem
Note that I'm using AVG cost
MichelV
Postby Mark » Fri May 08, 2020 7:49 am
Hi MichelV,
Instead of recording a 1:20 split, what really happened was a ratio slightly different than that. Record what happened, which it sounds like was a 163:3265 split. This is a ratio of <new shares> for <old shares>.
Usually when there is a fractional share involved, you get paid cash for that fractional share. If this happens, it would be a 1:20 split, plus a sell of the 0.25 fractional share. It sounds like that may not be the case for you in this situation though.
Postby MichelV » Fri May 08, 2020 8:14 am
Worked as expected. Never looked at it from this angle.
Many thanks.
MichelV
