Control price retrieval per sub-portfolio
Postby pauyo » Thu Jun 04, 2020 12:43 pm
Is it possible today to enable/disable investment price retrieval setting on portfolio level somehow?
It would be helpful for me to be able to, e g from (sub-)portfolio properties, to select if investment within that portfolio should have the internet price retrieve enabled or not. As of now I have to go to the properties of each investment within a specific portfolio and alter the check box manually, for potentially dozens of investments, to toggle the setting.
Regards,
Paul
pauyo
Postby Mark » Thu Jun 04, 2020 2:05 pm
Hi Paul,
Sorry, no, this isn't a feature. You _could_ use "File / File Operations / Hide Sold Investments..." to accomplish this. That feature can also turn off/on price retrieve, so you could run it twice, once with a very narrow date range for some date where you owned nothing, so that everything can be hidden and the price retrieve turned off for all investments. You could run it a second time for today's date, to un-hide everything owned as of today, and leave off the option to turn ON price retrieve for non-sold investments. It is a bit tricky, but it can be done.
Postby pauyo » Fri Jun 05, 2020 5:33 am
Thank you for the work-around you suggested. I will try it out.
Regards,
Paul
pauyo
